I'm experiencing this error on my M5 at the moment.
"Error
The camera may be in use by another application. Please close the other application and try again."
I've tried rebooting, factory reset,safe mode, and clearing data/cache of camera app. Nothing works!
I just got my M5 and I'm disappointed by this.
The camera worked fine the first week only. I haven't done anything to my phone nor did I drop it to cause such issue.
Can someone help me out?
Hi. Have you got a solution to this yet? I have had the same roblem with my M4 for nearly a year. I've tried soft resets, hard resets, complete firmware re-flashes using Companion app, the service formatting tools, and all sorts, but it simply hasn't worked. Recently I broke my screen, but that's not the cause, as until then it was extremely well treated.
Sony may claim that it's not a know error, but the number of people with this problem on th M4 and M5, it seems that there must be a serious problem, and surely most people are getting it resolved somehow (unlike me, who has livd with the problem for a year since it randomly started, probably after an app update.
Would be great to know how people have solved it, and if we are collectively any closer to working out what the problem actually is.
Thanks
P.S. Have even tried booting into Safe Mode, and the camera still won't work. I cant say that I'm at all impressed with this phone. Between the charging problems I first experienced, the mixed quality sony representatives and responses, and a phone that has severe memory shortage, and can't use the SD card for storing apps without using tweaks and hacks. So clearly, the phone has a few serious issues, and not having my phone camera working for a year is just one of them. I'm just one person, so how much does Sony care about sorting out client problems? I guess the lack of response to all the posts worldwide about this problem for the last year and more are just a reflection of how Sony's focus is not on customer satisfaction through issue resolution and avoidance, but instead through new product releases promising improvements, whether realistic or not.
I too having the same exact problem, Back Camera not working but Front works in 3rd party applications from play store. I tried reset, Software repair nothing works. Finaly i took my mobile for service , they replaced the back camera with new one, but the same error exists. The problem is not in the camera. this may be software issue or motherboard issue, Sony Has to reply the cause for this problem. Thank You
3days ago my sony xperia M5 is not working the camera, when i use the front camera the message is
"Error Camera may be in use by another application"and the back camera is also not working..i tried to factory reset then the camera is working and when i front the camera back to problem again
what can i do? almost 2month i used this phone.
I agree with you
any updates on this sony it seems that it is a firmware problem on your end. Because it also produces bugs on the firmware I can't even make use of the apps because of this.. please a fix for this sony I already have regrets on buying this phone..
