Change PIN
Ebe1
Change PIN
Anytime I want to change my pin, unfortunately settings has stopped will appear.  How do I choose a new pin.
1 REPLY 1
Jonas
Master
Hi @Ebe1, sorry to hear about this. Slightly_frowning_Face
If I understand correctly, you are still able to access the Settings menu? If you are, go to Settings > Apps > tap the three dots in the top right corner > Show system > scroll down and find "Settings" > tap on it > Storage > Clear data > OK.
Once this is done, try changing your screen lock and see if it still crashes.
Let me know if that helps! Slightly_smiling_Face
