I have the KDL-50W755C, Bravia 2015 Android TV. Unfortunately, the time is wrong - its time is 88 minutes in the future. I wanted to change it in the settings, but all options are greyed out. When I go to "Settings" --> "Date & Time" --> "Time", only the option "Use 24-hour format" is available. All other 3 options, one of them "Set time", are greyed out. The time zone is the correct one.
So now the TV is showing a wrong time and is not allowing to change it. What can I do about it?
Thanks for your help!
I can't changed it from broadcast to network, because it is grayed out?
Is there a way to enable full access to settings options?
Hi @nenadx
It seems like I am having the exact same problem. Have you been able to solve it in the end? And if so, how exactly?
Kind regards,
Wouter
And how to activate that guide? I have the same problem:
Greyed out date/time options. AND not being able to GoogleCast (after software update on TV). 2018 model bravia.
I have exactly the same issue. I think it came out with the last Android update. I reset the TV’ the time went ok. But then, I unplugged the cable for other teasons, and the time was wrong again
Sony's help desk responded by now. The problem is indeed that the time can't be synced with a broadcast signal if you don't have a tv connection (I have only an internet connection). The reason for the fact that you can't change what your TV syncs with is unclear. However, it can be solved by resetting to the factory settings, and setting your country to a neighbouring country. For example, I live in the Netherlands, and if I set it to Belgium, the settings are unabled again. If I change the sync option to 'Sync to network', the time is set correctly. Coincidentally, casting to the TV works again as well. Hopefully this helps other people with this same problem.
So this happens in 2015 and now again in 2019 !? Same crap development team?
but the tip of changing country to 'not your own' seemed to work
H O W D O E S T H I S T V S Y N C I T S I N T E R N A L C L O C K ?
Time config through the menu is clearly bugged and i cannot get it to work...
This morning out of nothing it thought it was living in 2016...
I've read it syncs its time through dvb-signal but what if i only use internet???????????
All other devices work fine on the network (right date and time). Also I have a NTP daemon installed on a network client (acting as a local NTP server)... NOTHING happens on the Bravia, it's not picking it up!!!
What is going on here???
Options to manipulate time are greyed out on the TV - WHY!!!
Hi @Wernervs . Did you try the solution that worked for me (see above)? Perhaps that will help for you as well.
