Can’t open privacy policy
smplkd
New
Hello,
I updated to the latest software this morning, but I don’t have a Bravia remote (broke early on). I usually use my Sky Q remote, or a Remote App.
However since the update the App or Sky Q remote won’t work, so I can’t open the privacy policy to then confirm it. So I’m stuck at this screen that says Updated Privacy Policy - Open Privacy Policy.
Any advice would be greatly appreciated.
5 REPLIES 5
LightFoot
Specialist
Hi @smplkd
What is the full model number of your TV, it starts with KD? Probably the quickest solution is to buy a universal remote from most supermarkets or electrical shops.
Obviously depending on your model number, there maybe an OK button and direction buttons on your TV
Mmmacken
New
Hi! Did you happen to find. Fix for this? I have the same issue!  Thanks !
Mmmacken
New
@smplkd hi! See message above, if you found a fix and wouldn’t mind sharing that’d be great! Tried getting universal remote but you can’t program it since we are stuck on the privacy screen.
rooobb
Astravvtpaul
New
Anyone answer this problem as I have the same issue.
