XP Driver for VGN-SZ4XN/C?
Filodicapello
Is there a way to obtain the Windows XP drivers for the VGN-SZ4XN/C?
I was able to install XP on the FE41S using the XP drivers for the FE31Z: maybe a similar solution is possible...
Can anyone suggest me a solution, please?
1 REPLY 1
Blencogo
I suggest you try the same but using the Preinstalled XP Drivers and the Preinstalled XP Utilities from the SZ3-Series of Vaios
As with the FE41S, you will need to copy your existing VCC4 Camera Driver and use it under XP as the SZ3 Vaios have a different Camera. You also need KB888111 for the sound to work with XP.
:wink:
