V2M bios error message
bigscreen
hi
I am currently receiving a bios error message on startup
LCD fan is abnormal!
LCD temperature is abnormal! and suggests that you look in the hardware monitor in the bios for more information
There however does not seem to be any detail in the Hardware monitor that is linked to the LCD
has anybody else had this problem before?
I have had a look inside the unit and can see nothing wrong, all of the fans appear to be working directly.
I am not aware of any Bios updates that have been released for this machine lately
2 REPLIES 2
Thalamus.
Champion
Hi bigscreen
There is a BIOS Version : 2003V2 update available which is listed as fixing the following issiues:
- Hardware monitor error of Vcore voltage.
However you may have already updated your Bios as it's not a new update so I'm not sure if it would solve your problem.. :slight_frown:
bigscreen
Thalamus
Many thanks for the response.
However you are correct, I already have this bios update installed and this problem only started a few days ago, I am hoping that this is not the start of a replacement LCD
Happy New Year to you
