i have put some pics into my vaio under USER_001 and when i disconnect the mp3 player from the pc i can not see the pics it says that there is no pics in the file what shall i do to see them? thnx
are you trying to put pictures on to the mp3
ye onto the mp3 player
there should be a folder there alredy. on mine i have voice( for voice recordings), Music ( for my mp3's). so there should be a folder for them.
What MP3 player is it?
its the sony vaio pocket.
ok.
i am not sure then.
A couple of thoughts.
The USER_001 folder is in a "VAIO Photo" folder isn't it!?
Are you disconnecting the vaio from your PC "properly" - i.e. with "safely remove hardware"?
Oh, and after you put the pics on and disconnect - if you reconnect, are the pic files there?
What kind of pictures are those ? I mean, are they jpeg, or something else ?
Are they pictures you took with your digi-cam ? Is so, what kind of digi-cam ?
Did you manipulate them with a third-party coftware such as Photoshop ?
after hours of playing with it to try make it work i managed to get it workin thnx for all of ur help
