Hello everybody,
I have a question regarding my VAIO's webcam. It is a VGN-FE31H and the webcam is VGP-VCC1. My question is: Can it record video? And if yes, how?
Tanks,
Brian
Go into the 'video capture camera utility' in your start programs menu and choose settings, video 640x480 max and set the quality to as high as you need but be aware if you are sending your recording the file may be larger than necessary. Test various sizes.
Thank you, but I have no start menu 'VAIO capture camera utility'. In the program files folder I have a 'VAIO Camera Utility' Folder with two applications VCUServ.exe and VCUSet.exe and some dlls. Is there anything I should do?
Brian
