I have a Vaio AR11S and I understand it has a hybrid tuner, capable of receiving both analogue and digital signals. Does this mean I can watch/record 2 different channels simultaneously?? and if so, how do I get it to work with media center?? At the moment I can only watch/record one channel at a time . any help much appreciated!
Hi Japps,
Welcome to Club Vaio.
No unfortunately you can only watch and record one channel at a time..
Is it possible to play games on the AR series? For example, on AR21M?
Does it require other external connectors?
Because:
1. Seen the Ad flash ("Showcase - take a closer look") for the FE series which shows you can play gaming console on your FE series.
2. Heard you can play games on some laptops with high configuration + which has a S-Video out port (which the AR & FE series have)
Sorry, i know its not related to this post...but just wanted to know.
You can only watch and record one channel. Hybrid just means it can get digital and analogue channels
I have Media Center. How do you watch channels on it? Please could somebody explain.
does your laptop have a built in TV tuner or USB TV tuner?
Ok where do i find that if it has?
Vgn-N11M. So i dont probably have it.
No Waqz - your N-Series is too small !!!!
You will need ONE OF THESE to watch and record TV on your Vaio.
