Don't increase system police size when you run Vaio Recovery Center
profile.country.fr_GB.title
pichabe99
I will inform you on a problem I have got with the Vaio Recovery Center.
I use the French version of Vista on a Vaio AR 51 SU. The screen image
size is 1920 x 1200. I changed the system police size from 96 to 120 dpi
using "Control panel \ Personalization".
I try to run the Vaio recovery center which uses the system police.
Because the size of this police is increased, character strings in the
application window become longer. So, I cannot see any more the command
buttons below the window because its size is fixed.
So don't increase system police size when you run Vaio Recovery Center.
0 REPLIES 0
