Is there a way to bypass the MCE IR blaster crap when setting up a TV using S-Video inputs from SKY box? I can live with changing the channels manually.
During setup I have perfect sound & vision but then the last setup stage (IR remote setup) dosn't work, it decides to not allow you save any of the previous setup options. Result: no TV.
Is there an option to turn off this remote stuff on MCE or maybe another way to communicate with the TV not using MCE???
No, it's not possible to bypass it which is very annoying.
