KDL-46W5500&DLNA
profile.country.CZ.title
reneare
New
KDL-46W5500&DLNA
I am not able to view films/movies in HD via DLNA fluently. The films are often interrupted (cut/stopped). I have tested PS3, Mezzmo, TwonkyMedia server and various storages (NAS servers), ... and nothing helped. When I am playing DVD or DivX films from the same media server via DLNA everything is OK. I am using 100Mbps network. KDL-46W5500. Please help. Rene
Message was edited by: -frank-
Tags (4)
9 REPLIES 9
Catmambo
Contributor
Ok so SD content works but HD content has buffering problems?
Does it work ok when streaming from a PC to the TV or is it jut when from server to the TV?
Can you go into a bit more details about your setup and what you've tried so far?
thanks
reneare
New
I tried streaming from laptop (I tested WinXP and Windows7) whith various DLNA servers (PS3, Mezzmo, Twonky media, ..). HD video is stored on 2x1TB HDD (RAID0) connected to laptop via IEEE1394 and I tested also connection of HDD via USB 2.0.
I tried NAS server (2x1TB, RAID0) with PS3 and Twonky media DLNA server as well.
The result is always the same - the video is not played fluently and often is stopped completelly.
Thanks for help
René
profile.country.en_BG.title
aisthima
try Wild media server
reneare
New
tested, the same result
profile.country.hr_HR.title
DamacizSi
Try Twonky via dlna, and fails not from HDD connected but stored on PC from PC direct.
http://www.sony-mea.com/support/resources/en_AP/html/Usefulinfo/DLNAFeatures/tv.htmlhttp://windows.microsoft.com/en-US/windows7/products/features/play-to
http://support.sony-europe.com/tutorials/tvhc/dlna/dlna.aspx?site=odw_en_GB&m=KDL-40W5500
supporterd fail formats for Your model
Obligatory                 Optional
Image     JPEG          PNG, GIF, TIFF
Audio     LPCM          AAC, AC-3, ATRAC, MP3, WMA9
Video     MPEG-2        MPEG-1, MPEG4 (incl. SP/ASP used by DivX), AVC, WMV9
Regards
Damac
darwisab
please be aware of the compatible video file formats. This information is also listed in the TV instruction manual.
You can check :
•COMPATIBLE video file formats are : AVCHD /   HDV /   MPEG 2-PS
you can check on http://sonycic.custhelp.com this article title for further information :
Which video formats are compatible via the DLNA Ethernet connection.
DamacizSi
Obligatory                                                               Optional
          AVCHD, HDV(MPEG2-TS), MPEG2-PS
http://support.sony-europe.com/tvhc/faq/faqkb.aspx?site=odw_en_GB&d=f&KBS=TV&m=KDL-46W5500&f=dlna
R
Damac
DamacizSi
If You ever try  http://www.serviio.org/ so give as feed back.
Regards
Damac
specialist-convergence
Hi, Most server software will transcode on the fly, it sounds like you have a buffering issue when transcoding your files, although the TV supports a lot of formats, most DNLA server packages convert to a single standard like MPEG2_PS for HD, in this case you need to play with the transcoding settings on your PC, it could be over transcoding and then cant buffer enough and the connection fails.
Regards
