switching off a KDL 32 ex 503?
gorlatha
When I press the power off button on the side of the tv the red light is still showing on the front of the tv as if it is on standby.  Should it being doing this?
Also has anyone had the tv automatically switching itself on when you come in the room or even temporarily switching to standby for a few seconds then on again when it's been on for a while?
thanks
2 REPLIES 2
slowtrain
Hi again
I have the EX403 version of the TV. I leave mine in the same state with the red led showing. You will receive updates this way providing it's connected to your BB router. You would need to unplug the mains from it to totally turn it off.
I'm sure there are settings you can adjust to prevent the TV turning off. It can happen to me if I'm watching the TV in bed and have not moved for however long, a message will pop up asking to press any button on the remote to prevent the TV from turning off. There must be a motion sensor built in looking to see if any ones in the room. It's quite clever, so it will turn off if you've left the room for any length of time or nodded off.
gofrost
the red light does'nt turn off straight away as internal processes are being switched off as for the tv turning off if you go into xmb and select settings-system settings -eco-power saving and/or idle tv standby you can adjust tv options
