i am very disappointed that I will not be able to access BBC iplayer on my Sony Bravia 32EX403. Is there any reason why Sony does not provide the upgrade?
Opgelost! Ga naar oplossing.
Hi there
This is a BBC decision. See:
The BBC site:
http://iplayerhelp.external.bbc.co.uk/tv/connected
Thread on this forums:
Cheers
Hi there
The BBC site:
Cheers
And me - VERY disappointed - would have thought that SONY had more clout with BBC. Not buying another SONY TV that's for sure.
Well, SONY may mark this as having been solved, but not for me it hasn't. I already have a NOW box, and it's not very good. What I want is that the SONY Bravia TV that I bought to enable watching BBC IPlayer should continue to do so without added bits of kit. It really is not too much to ask, is it?
Hi there
Sorry buddy, i marked this solved simply because there is no other answer.
Cheers
MY SONY-kdl32wd756 WOULD NOT PLAY BBC PLAYER ALTHOUGH IT LOADED UP,SONY TECH TOLD ME TO FOLLOW THESE STEPS TO RESET THE CLOCK TO A PREVOIUS TIME AS THAT IS THE MAIN CAUSE !!,DID SO AND ITS WORKING OK NOW...
YOU NEED TO RESET TO A PREVIOUS DATE/TIME I.E 30/09/2015 10.05 HRS (ALTHOUGH MINES 2016 MODEL,STRANGE OR WHAT ? )
HOME BUTTON
SETTINGS
SYSTEM SETTINGS
SET UP
CLOCK/TIMERS
CLOCK SET
MANUAL .
SET IT TO 30/09/2015 10.05 HRS
(IF "PLAYBACK CONTENT " IS ON LIST SELECT THAT , ERROR 02001 MAY POP UP , ALTHOUGH THIS WAS NOT LISTED IN MY SETTINGS)
YOU NOW NEED TO "REFRESH INTERNET SETTINGS SO DO THIS .....
HOME BUTTON
SETTINGS
SET UP
NETWORK
REFRESH INTERNET SETTINGS CONTENT ...
THATS IT,MY IPLAYER WORKED OK THEN .
Bought a 32 gb memory stick for my kdl32wd756 set, but it will not accept one that is less than 64 gb ,so be aware of that if you purchase a stick.
