How do I get an audio output signal to drive a loop aerial from a KDL-22BX20D
Peter
Solved! Go to Solution.
Hi Pehutchxk,
Thank you for posting your question @ Sony Forums
This model have only one auido output jack . It is the Headphone mini jack 3.5mm
You can find more details in the manual page number 23
http://pdf.crse.com/manuals/419304212X.pdf
Regards
can you run that question again with a little more info, so far from what you've said, you cant!
Thank you for your response
I am trying to get my T Loop Amplifier to work with a new TV. In the Handbook for the KDL-22BX20D, the only mention of an audio output is from the Scart connector
Using a scart plug with red and white connector, specifically marked OUT, I do not get a signal. On two previous Sony TV 's I have used there have been separate red and white audio output sockets.
Does that give you enough to go on ?
Peter
Hi Pehutchxk,
Regards
Thanks
You are always welcome
