When Youview becomes available, will it be possible to receive it on S380 BluRay player?
Solved! Go to Solution.
Hi
Do you mean *if*
On a serious note - no A brand manufacturer has openly supported YouView for a number of reasons. So the YouView proposition is focused on likely rather pricey integrated PVR/ Set top box products which will probably be cross subsidised by an ISP ( a la BT Vision).
So we have no plans to support it at the current time as we are focussed on providing a pretty much identical content experince via our own platform.
Hope this helps
Thanks
Hi
Do you mean *if*
Hope this helps
Thanks
