horizontal display issue
SOLVED
Not applicable
I've been possessing an Xperia Arc for some weeks now and I just noticed that when I turn the display horizontal and drag that notification window on the top down, everything in there starts to look extremply distorted...
Did anyone have the same problem or is it just me? And what can I do about it?
I would appreciate any help...
1 ACCEPTED SOLUTION
Accepted Solutions
another think you should do is
1) backup everything
this is how
http://talk.sonyericsson.com/message/108775#108775
2) use Update Service or PC Companion to repair and update your phone
3) if 2.3.4 it's now available yet you can manually update your phone
this is how
http://talk.sonyericsson.com/thread/23641?tstart=0
7 REPLIES 7
slimshaddy
Hero
ca you upload a pic or video for the same for us to understand better ??
i just checked it and i dont faced any problem you described..
uploading a pic or video may help a lot.
Not applicable
Sorry, I had problems getting the pics on the pc lol...
Here is the pic when it's normal, in vertical format
And this is when it's in horizontal format
that doesn't seem right
go to settings -> display -> auto-rotate screen check and uncheck and on Animation make sure ALL animations is selected
this is how
this is how
Not applicable
Thanks! After I repaired it like you said, it works again!
anytime, 2.3.4 it's quite nice, you should really look into it
slimshaddy
Hero
hmm gr8..
