Block contact
Jasmin91
Block contact
How do I block contact
1 REPLY 1
Martin1
Enthusiast
Hi @Jasmin91, let me see if I can help out here.
There is no pre-loaded feature in Xperia M4 Aqua enabling you to block numbers, however you can if you want to save the unwanted number as a contact and direct all calls from that number to voicemail. To do this, please follow the instructions below.
  1. Find and tap Contacts.
  2. Tap the contact that you want to forward to voicemail, then tap the Edit contact icon (icon with a contact and a pen).
  3. Tap the menu button (three vertical dots), then mark the All calls to voicemail checkbox.
  4. Tap Done / SAVE.
I hope that helped! Let me know if you have any further questions!
