How should I transfer images from internal memory to memory card?
nyfiken1
How do I transfer images from internal memory to memory card on my Sony Xperia M4 Aqua mobile phone?
Hur ska jag överföra bilder från internminnet till minneskort?
Hur ska jag göra för att överföra bilder från internminne till minneskort på min mobil Sony Xperia M4 Aqua?
2 REPLIES 2
Uliwooly
@nyfiken1
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Download a file commander app > open the app > internal storage > select the folder that you want to transfer > cut or move to > SD card
don't forget to grant permissions to the file commander app.
Jonas
Master
Hi @nyfiken1, welcome to our forum!
I can see that you have already received great help from @uliwooly, but there is an easier way to do it that doesn't require any kind of file management application.
Go to Settings > Storage > Transfer data to SD card > choose the data you want to transfer and then tap on "Transfer".
Let us know how it went with transferring your photos! Slightly_smiling_Face
