Sony SEL 20 1.8 G
hans171160
Sony SEL 20 1.8 G
Good evening,
I am a proud owner of a wonderful 20 mm 1.8 G lens, but a bit worried though. When tilting the lensup and down wards, the inner lens package slides with the movement in the housing (lens is not attached to the body). Are you having the same experience?
Looking forward to receive your helpful advise.
Amfion
Hallo @hans171160
Dat komt doordat het een lens is met lineaire motoren. Bijna alle nieuwe lenzen hebben datzelfde. Het klinkt een beetje apart maar er is dus niks aan de hand.
Groet!
Antonette
5 ANTWOORDEN 5
suzanne_sony
Hi @hans171160,
Thank you for your message.
I have forwarded your question to the relevant department and will get back to you as soon as I get a reply.
Kind regards,
Suzanne
hans171160
Great Suzanne, I am looking forward and thanks for the help!
Amfion
Hallo @hans171160
Groet!
Antonette
hans171160
Hartelijk dank voor de geruststellende informatie!
Amfion
Graag gedaan!
