Hi i have the above reader, i want to connect usb headphones ,can i use a mini to standard usb adapter plug the mini into the reader ,then plug a wireless adapter from headphones into the other end of the usb, and then the headphones will work without wires ,any help would be good thank you regards Jomo
Opgelost! Ga naar oplossing.
Hi john404,
I don't know for sure but I doubt this would be possible because there wouldn't be any drivers, etc to support audio via USB..:smileyconfused:
