Use VPN on Sony android TV XD55xe8096
savi176
New
How can I use VPN on my TV XD55xe8096?
It doesn't work for me aand I tried all the VPNs
Thank you!!
2 REPLIES 2
Drewde
Administrator
Is there an app you can install?
Thanks,
Drew
joelippa
I can't say I've ever tried it but if your 55XE8096 performs as poorly as my 65XE8596 I wouldn't bother putting more load on it. You'd probably be better off letting some other device do the job. A router running OpenWrt or DD-WRT could work depending on what VPN server you need to tunnel to.
