Sony 9305 connecting to Wifi - Can't find Select-button
veispe
Hi, I bought Sony 9305 and I tried to connect it to Wifi. In the Password-field it says you should press Select-button. I can't find it. There is no Select-button in my Remote-control. Is there any solution to that?
2 GEACCEPTEERDE OPLOSSINGEN
Anonymous
Niet van toepassing
Hi there
The on-screen keyboard (pic below) should appear on the screen upon pressing the 'select' or 'OK' button upon going into the password box.
Step 1:
When you get to this Screen:
Step 2:
Press this button:
Step 3:
This screen will appear - Type in your Wifi password.  To change to upper and lower case, use the Up arrow button on the onscreen keyboard
Cheers
veispe
I turned my tv to english. It looks like it helped! Thanks!
13 ANTWOORDEN 13
Anonymous
Niet van toepassing
Hi there
The 'select' button they are referring to is probably the middle button between the arrow keys (also referred to an an 'OK' button).
Cheers
veispe
Should it open a text and numbers field where I can pick up letters and numbers?
My password contains capital letters and numbers. When I press remote buttons there comes only numbers. No letters.
Anonymous
Niet van toepassing
Hi there
Without knowing exactly wants on your screen its hard to answer - but yes you can or should be able to input Text, Numbers and special characters.  Sometimes theres a button on the onscreen keyboard that you press to change between them other times pressing the red button on your remote control will do it.
Same as changing the case from lowercase to uppercase.  Theres a 'shift' button on the onscreen keyboard (arrow pointing upwards).
Cheers
veispe
For some reason there comes no text and numbers field on the screen.
My remote has letters but I can't select them. Maybe there is a solution to that.
Anonymous
Niet van toepassing
Hi there
Step 1:
Step 2:
Press this button:
Step 3:
Cheers
veispe
I've tried every trick. I connected LAN off. Still I can't connect to Wifi. There is no way to get text and numbers to screen and remote control gives only numbers.
Why is this so difficult?
veispe
Ok, I'll try this. Let's hope it helps.
veispe
Didn't work. Cursor just blinks in the password field. No keyboard on screen.
veispe
