Hi all - thanks for all the informative information I have found on this community site.
I have recently purchased the above tv and I am using it with a (UK) BT Ultra HD package. The output of the box is 2160p50 and I have set it to 10 bit colour.
Generally speaking I am very happy with the telly but I am experiencing a bug which sounds similar to the "Screen Format: Full" issue reported on another thread.
After a period of watching TV (normally longer extended periods of say 2 hours), the picture starts to judder and the "Screen Format: Full" message flicks on and off. The only way to recover this is to switch the telly off and on again which seems to allow the telly to "resync". This problem happens *every* day when watching TV at least once.
It is not a problem with the BT box as when I switch that on and off the picture problem does not clear.
I have tried different 4K related settings on the telly / BT box but the problem still occurs. Has anyone else noticed this with the TV ?
Thanks,
Ian
Opgelost! Ga naar oplossing.
I don't see any 2015 tvs the d denotes the 2016
I think the 2015 have nothing
I have found the 2015 tvs do have the update.
But my experience of usb updating is that it's hazardous.
Is it tabled to be over the air at all?
frankie1g wrote:Is it tabled to be over the air at all?
As written above, unfortunately no - USB Download update only.
To the people who say that the update patch has not worked:
If after that, and still doesnt work, please reply back with:
It might also be helpful if you could create a short video clearly demonstrating the problem as well as showing the firmware version in the video.
Cheers
Updated my 75xd9405 and had the juddering tonight while watching the ryder cup 😞 I got a video of it but didn't think it was worth uploading it to youtube cos it would only get taken down by sky. I hadn't at the time it happened done a factory reset but I've done one now and will see how it goes tomorrow. It did seem to take longer to happen, i'd probably been watching it for 3 or 4 hrs before it happened but when it did it was every bit as bad as it was before..
Can you clarify what you mean. A factory data reset or an initial setup option?
im not keen on having to re download apps and set the picture up again if I can possibly avoid it.
The erase all data option I think it is, and I didn't want to do that either as it's hassle and I've had my tv calibrated so will have to reenter all of the calibrated settings again!
@zAndy1uk wrote:The erase all data option I think it is, and I didn't want to do that either as it's hassle and I've had my tv calibrated so will have to reenter all of the calibrated settings again!
Just take a screenshot with your phone of all the settings. Does not take long. I just did a factory reset on mine as getting SkyQ on Tuesday. People are so lazy lol.
Hi All
Instructions on how to do a factory reset:
https://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/66442/
Cheers
