Camera bought for me - admittedly 'used' however everything in box was sealed.However upon charging battery and using camera I have experienced a rapid clicking upon shutdown.
Is this a common or normal occurence? Want to stick with it cos its a nice camera but not if its faulty.
Solved! Go to Solution.
Hello shiftytigger - welcome to the Sony Forums
This may indicate a physical fault with the shutter mechanism (which may be fixed by safely cleaning dust from within the camera body) or another internal component and I would advise you to contact Sony Customer Services to see if a repair is needed (if it is necessary, they will be able to advise about cost). If the clicking is more of an electrical noise than a mechanical noise, this may be a little trickier to repair.
Full details are available here:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon
Thanks,
Simon
