Struggling with the panorama function on my Alpha 77. It worked on the first day but since then it comes up with an error when I try it and tells me to move the camera slowly. Anyone else suffering from the same?
Solved! Go to Solution.
Hi scmills8858,
welcome to Questions & Answers..:smileyhappy:
Not sure if will help but have you installed the Firmware Ver.1.04 update.?
If not here are links for the updates, not sure what operating sysytem your using so have links for both flavours..:smileywink:
Hi scmills8858,
Thanks Thalamus,
I haven't updated to 1.04 as yet. It didn't mention that it solved problems with the panoramic function but might be worth a try anyway.
Message was edited by: scmills8858
