Sony Vaio T Series Ultrabook Backslash Key missing
SOLVED
petergable
I have just purchased in the USA this fantastic machine but I have a slight problem with the keyboard.
I installed the English language pack and can find the £ sign where the # key is (Shift3) I can live with this.
The # key is however on the backslash key and I really need the backslash when logging onto my server.
Please can someone advise where I can find it as the only option is to copy and paste from a document with the backslash in. Not ideal.
Its Windows 8 by the way.
Thanks in dvance.
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
I'm not sure if the MKLC installs on Windows 8 - but you can create your customised keyboard layout by downloading MKLC onto a Windows 7 (or any other) machine and then you can copy and install your new keyboard layout on your Windows 8 Vaio.
http://www.neowin.net/forum/topic/1061262-microsoft-keyboard-layout-creator/
:thinking:
3 REPLIES 3
Blencogo
Hi petergable and welcome.
A common problem where you have to either lose the £ key or the \ key.
Have a look at this Tutorial for re-mapping the UK # key to add \ when Alt Gr is pressed, and | when Alt Gr + SHIFT is pressed:
http://andrewbradford.co.uk/blog/tutorial-remapping-a-us-keyboard-in-the-uk-windows
:thinking:
Blencogo
:thinking:
petergable
Thanks very much...problem soved.
