Keyboard problems (wrong letters on the screen)
Empiucci
I have cleaned the keybord on my Vaio b1xp. After this my keyboard has become crazy.. Wrong letters shows up..
For example, when I press an "e" a "2" shows on the screen instead of the "e"..
Can someone help me?
7 REPLIES 7
Empiucci
I have also tried to uninstall the keyboard driver and install it again.. the keyboard is still crazy.. someone had the same problem??
wharfshrimp
have u checked the keyboard format setting and seen th@ it is still set @ uk/us format?
Empiucci
how and where do I check that? (btw. thanxs for the help)
wharfshrimp
goto start then control panel and then printers other hardware, click keyboard, then properties.
Empiucci
Hmm, yes it's correctly set up.. don't know what to do.. Any more suggestions??
feederfan
how did u clean it?
did u use chemicals or solvents of sum sort? maybe you have damaged the membrane that controls what keys the computer thinks are being pressed?
kee-lo_
I'd have to agree with FF, you may have damaged the membrane of the keyboard.
