how to connect wireless mouse to A297XP
Benpete
Probably a stupid question, but how can I connect the wireless mouse provided with the Vaio A297XP. There is a connect button on the bottom but that does not bring any difference. The manual also does not give a clue.
3 REPLIES 3
twynne
On mine I just turned the power on using the switch on bottom of mouse, then hit connect on the laptop base and connect button on the mouse - they found each other instantly.
BurastA
well depends on the model of your wireless mouse. If its an a4 it finds instantly when you press connect(but be sure that the channels are the same on both the receiver and the mouse-om mine the channel switch on the mouse was somewhere under the batteries if I dont remember wrong)
If it is a microsoft press the connect button on the mouse and the big button on the receiver as well. They should find each other automatically
Benpete
OK, thanks both, it works now!
