Bluetooth ActiveSync
neilw
I can't get ActiveSync to work between my TR2MP and an IPAQ 2210 PDA using bluetooth. It works with a USB connection, but when using bluetooth the IPAQ connects but is not recognised then disconnects. Is there a soloution to this problem?
3 REPLIES 3
LT
I tried to install a microsoft mouse/bluetooth and it did not work direct with the bluetoth from my Z1RMP
Whart could be the solution?
jkeepi
The problem you are experiencing is because of Sony's non standard Bluetooth implementation. The problem is with the bluetooth stack, not the bluetooth hardware.
I followed the advice from ebe on this forum (http://www.geekzone.co.nz/forums.asp?ForumId=6&TopicId=656) and managed to get my iPAQ 2210 working with ActiveSync. Just follow the advice to the letter and you should no no problems.
Hope that helps ya...
neilw
:slight_smile: Many thanks for your constructive reply! I have printed the ebe instructions and (possibly after a whisky for courage) will try what he suggests.
