TV not switching on
SOLVED
fitzgerald62
TV not switching on
I had power to my TV yesterday...the socket has power--confirmed. Is there a way to see what the problem is or is there a special reset or something if a breaker inside the TV goes...am unclear how it won't turn on via the remote or manually at the TV
Message was edited by: Catmambo
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi fitzgerald62,
welcome to Questions & Answers..:smileyhappy:
If their is no power to your Bravia then I suggest you check the fuse if still no luck then I would recommend contacting your Local repair specialist..
I suspect that your Bravia does not have a physical on-off switch but to be sure let us know what model Bravia you have.?
3 REPLIES 3
Thalamus.
Champion
Hi fitzgerald62,
kennedy24
sony  model no kd55xf8096
royabrown2
Hero
@kennedy24
What result did you get when trying the 12-year-old solution to this 12-year-old post?
