Sony Bravia 32WD757 channel sort
SilverGreen93
New
Just bought a 32WD757 TV and scanned all digital channels automatically.
Now I can't find any option to sort the channel list alphabetically. How do I do that?
I also noticed that the Programme List Edit option from the Digital Setup menu is grayed out (not selectable).
Can anyone tell me how to do that?
Thanks,
Mihai
5 REPLIES 5
Piscie
Hi SilverGreen93,
Try to sort the channels manually with Sony Channel Editor tool. You can download it on your PC from here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32wd757/downloads/0001...
Hope it helps!
SilverGreen93
New
Thanks for the app. Will try it.
So you are saying that this relatively expensive Sony TV is so dumb that cannot sort the channels alphabetically without using a PC to export and re-import the channels?
I cannot believe the software is so dumb...
Also, If I use the app to sort the channels, will this change the channel number associated with the channel?
Bat_Rick
New
Hi Silver,
You can sort the channels using the TV menus, check this link page 20 to know how.
royabrown2
Hero
@Bat_Rick
Are you reading that under Analogue -  Programme Sorting - which doesn’t apply here?
Or under Digital - Programme List Edit - which @SilverGreen93 has already said is greyed out?
Piscie
It's not supposed to be grayed out.
Make sure that your software is up to date and then test again. The latest version is v8.229
