KDL-47W805A TV message of system memory limit.
SOLVED
Vanquish206
Sony KDL-47W805A :I have a Sony kdl-47w805a which shows the following message when I try to open iPlayer
"tv internet download failed because content size exceed system memory limit."
Can I clear or increase the memory or can I not get iPlayer anymore ?
What does it actually mean ?
My tv is only 3 years old.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi All
The BBC has posted this message this afternoon stated that the issue has been fixed:
Thank you.
102 REPLIES 102
Anonymous
Not applicable
Hi there
Two things as general advice:
  • Turn the TV off from the power point on the wall for 2 minutes
  • When you switch the TV back on, do a "Refresh Internet Content" in the Network Settings area
If that still fails, it would be best to report this issue to the BBC themselves - as Sony does not have much control over the running of the iPlayer app.
https://iplayerhelp.external.bbc.co.uk/tv/forms
According to the BBC:
http://iplayerhelp.external.bbc.co.uk/tv/connected_tvs_dec2016
There is a general message about iPlayer not loading - however it is only mentioning LG (fixed) and Samsung (Under investigation).
Cheers
Am getting same problem with 3-4 yr old KDL 42W653A. Only started today.
Have had no previous problems accessing.
Have tried to raise issue on BBC iPlayer Help but their site is worse than useless.
Looks like the problem may be theirs, but we could do with some pressure from Sony as it looks like it could be a systematic problem.
Have tried access via another TV with Ryko stick and it is fine,
Anonymous
Not applicable
Hi All
I have emailed one of my contacts within Sony to see if they can liase with the BBC.
Cheers
Anonymous
Not applicable
Hi All
The BBC have now confirmed that they are investigating this issue:
http://iplayerhelp.external.bbc.co.uk/tv/sony-memory-limit
Cheers
Vanquish206
Thanks so much Quinnicus for helping with this problem.
When I got in tonight, I turned everything off and then on again and as expected the same message was displayed.
Thank you for your response and for raising the query with Sony and the BBC.
Hopefully the issue will be resumed quickly.
Kind regards
neil6167
I had this on both my KDL-46W905A and BDP-S790 yesterday, just checked and the Blu-Ray player accesses iPlayer content fine today, TV still fails with that message.
Anonymous
Not applicable
Hello All
Unfortunately this issue remains unresolved at present time.  Both Sony and the BBC are aware of this issue, which is still under investigation.
Thank you.
Mine is also 3 years old, but tonight back to working! Very odd
Anonymous
Not applicable
Hi All
Thank you.
