Suggestion: Pre-buffering on A1 (and A9)
SOLVED
profile.country.SE.title
joakim1024
I, and i suppose MANY others, would be thrilled if Sony would add pre-buffering in a future firmware update.
(is this already in the works?)
What i mean by pre-buffering is that when you half-press the shutter button the camera starts taking pictures, stores a set amount in the buffer (not on the card), and then when you press the shutter all the way it starts shooting as normal but also saves the images currently in the buffer - thus you will get images from 1-2 seconds BEFORE you press the shutter all the way, and you will get THE moment!
Some other brands/models already have this function , and i don't understand why this is not even a function in the mighty A1, marketed as the ultimate action camera?
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
You can reach out over the regular support channels via phone, email, or chat. I usually go for email personally.
5 REPLIES 5
Joe_Dohn
Specialist
Have you tried reaching out to the Sony support reps to leave your suggestion as feedback?
joakim1024
Hi John,
No, im not sure what channel to use to reach Sony rep about suggestions like this.
Joe_Dohn
Specialist
joakim1024
Thanks!
I sent the suggestion by e-mail.
Joe_Dohn
Specialist
Glad to hear it! I also sent an email to lend my voice to this suggestion ^^
It'd be really helpful to others if you mark your thread as solved so others can know to send their feedback as well, hopefully if enough people care, it gets added!
- JD
