Hi
We have a XAV-60 mounted in a coach and we would like to activate the rear facing camera, we did have it working via a switch on the dash but as we don't have the wiring harness for the socket on the rear the activation wire from the switch was connected to one of the terminals but we don't know which one.
We had to remove the unit for a wiring repair behind the dash and the wire came off the terminal it was attached to and we don't know which terminal it was.
Does anyone know which pin we need to attach the wire to, its the one that would normally come from the reverse light switch but we have a manual switch on the dash fitted?
Many thanks
Derek
Usually the XAV-60 is only compatible with the XA-R800C camera. Not sure of the exact terminal port due to the fitted switch, but this camera should fit right in with it's pins. You can find this info in the manual link here (page 42).
