Solved! Go to Solution.
first few days of using the device is not the best time to measure battery life, there lots of background processing happening ( indexing and calibrating and stuff)
try to search "battery drain" on the search bar above to view possible solutions
Are this 6 hours of DOT with maximum display brighness? I think this is one of the most power consuming things...
I´m thinking about a switch from z3 to x performance but battery performance is a thing i´m not sure about...
Can someone tell me what is com.qualcomm.qti.tetherservice? My battery is drainig and I got 40% of usage by Android System.
Is this OK for battery life? From unplug I did not use my phone, only mailing. I am concerned about Android System getting so high. And in Android System, com.qualcomm.qti.tetherservice is in proces. Is this alright?
just got my phonme yesterday and the phone is draning too much the battery compare my to Sony Z1.
I restore the same applications with the same settings, and I unplugged to phone, move around without playing with it. After 2h the battery at 89% for the X, and 96% for the Z1.
