Opgelost! Ga naar oplossing.
@Albo_underhill Settings - apps, tap on 3 dots, scroll down to contacts storage. There, you can find the storage tab, tap on it and clear data. This will erase your locally stored contacts.
Did you have a backup of your contacts or somewhere to sync them back?
Hi @Albo_underhill,
Welcome to the community.
I am sorry to see that you lost all your contacts. Did you happen to have a Google account set up in your phone?
If so, go to Settings > Accounts > Google > Your gmail address > 3 dots > Sync Now. This should retrieve any contacts that were synced with your gmail account, which would have been turned on by default. I hope this helps.
@Albo_underhill I am sorry to hear this, hope all the best.
When I said locally stored contacts, I forgot to mention you should also back up what you have because I thought you realized that's what should be done.
Can you check if there are other filters to set in contacts app?
If you want to manage your contacts easily then use your computer and open contacts.google.com
