BDV-E2100 freezes at start-up
profile.country.en_BE.title
cebaele74
I have a new BDV-E2100. I installed it and also did the firmware update right away. When I now start the home cinema, one out of two times it will start up and show the menu, and then completely freeze. The only thing I can do is pull out the power plug to restart it. But for the other 50% of the time, it starts up correctly and works OK. Anybody has a clue?
1 ANTWOORD 1
Anonymous
Niet van toepassing
Hi cebaele74,
Welcome to the Community of Sony NL.
As this Community is mainly intended for Dutch and Flemish people, it's recommended that you ask your question in the Dutch language. If you prefer to communicate in the English language, we'd like to refer you to the English Community which can be found at http://community.sony.co.uk
Beste cebaele74,
Welkom bij de Community van Sony NL.
Aangezien deze Community met name is bedoeld voor Nederlandse en Vlaamse gebruikers kun je je vraag hier gewoon in het Nederlands stellen. Mocht je liever in het Engelse communiceren, dan kan dit beter in de Engelse Community op http://community.sony.co.uk
Met vriendelijke groet,
