Clouding on W805 bottom corners
profile.country.fr_FR.title
Nalex74
Bezoeker
Hello, I just bought a 55W805 and I have a huge clouding effect on the 2 bottom corners of the screen. Does anybody can profide efficient setting which allows to make those white shadows disappear ?
Thank you.
5 ANTWOORDEN 5
Bravia55HX
this is one of the new models which i'll take a bet not many have got calibration settings for yet, you could start by turning down the backlight to around 3 or 4 then adjust other picture settings to your taste, a good rule with these sets is not to use the "vivid" setting as for most its too " in your face", i was surprised however that the dealer that provided you with the set did not set it up for you.
gofrost
Thats surprising i've just got the 55W9 and the picture is stunning straight out of the box using the home setting for the display.
profile.country.da_DK.title
Nielsen
If any of your settings aren't turned exstremely out in range, I'll suggest to return the unit. I had a similar issue on my set, which only vanished after total fall out, repair and re-calibration. Either SONY has an ab fabric calibration issue or more likely did your retailer sell you an unit that someone has tampered with.
Catmambo
Ooh gofrost - you bought the 55W9 ? I'm sorely tempted. What do you think?
Welkom bij Sony Forum.
Dit is een Nederlandstalig forum dus in het Nederlands schrijven wordt aangeraden, zodat de andere gebruikers makkelijker kunnen helpen.
Schrijft u liever in het Engels, dan kunt u het Engelstalige forum vinden, door boven aan het scherm de Nederlandse vlag te veranderen door eenmaal op te klkken en de Britse vlag te kiezen uit het menu.
met vriendelijke groet,
Welcome to Sony Forum.
This is a Dutch language forum so it is prefered you post in Dutch, so the forum users can help you more easily.
If you prefer to write in English, please find the UK forum by clicking on the Dutch flag on top of the screen and choose the British flag from the menu.
Kind Regards,
