Sony srs xb21 speaker not holding charge
Barlow234
as title says,my Sony srsxb21 Bluetooth speaker will not hold charge.
its about 4 month old and I have charged multiple times but charge light always goes out after like a minute.
i even bought 2 different chargers to see if it was that but nothing.
i bought Sony as is one of the best brands for speakers so really did not anticipate this.
anyone else have this problem?
many thanks
7 REPLIES 7
IamNic
Hello @Barlow234,
if the charge light goes off, that usually means the battery is topped off (full).
- Nic
Barlow234
Hi Nic,
The light goes off after like 1 minute maybe 30 seconds sometimes and when you turn it on there is an audio that says how charged it is, ie 50%,20% etc.
i charged for 18 hours over Xmas and when you turn it on it says battery low please charge so about to die.
Barlow234
Any ideas if there is a part or something I can order?maybe a battery??
IamNic
Hello @Barlow234,
first we need to verify if the software maybe reads your battery status wrong.
Have you tried to reset the speaker?
Here is how that works:
https://helpguide.sony.net/speaker/srs-xb21/v1/en/contents/TP0001599386.html
https://helpguide.sony.net/speaker/srs-xb21/v1/en/contents/TP0001599387.html
- Nic
Barlow234
thanks for getting back.
yes I tried this a few times when it first happened and no luck.
any ideas?
graham
IamNic
Hello @Barlow234,
then I think it would be best to check with support.
- Nic
JanisLP
hello,i want to let you know, i found an issue on this speaker,feels like it was my fault,because i had same issue, i charged wrong with fast charger,there is voltage output wrong 2.0 A ,this is to strong for speaker ,speaker needs input 1,5 A , and if its less,its better i think !  because if you charge battery longer then voltage - power in battery keeps longer,now im been listening speaker last night more than 10 hours,its perfect !  can you try,maybe can help to you is well !
