Sony Clie NZ90 charging question
Didn't know what category to put this in.
I've had one of these for around 15 years and going to start using it again.
Instead of using the cradle I will be using a USB cable to power it via a power bank. Battery could do with replacing but I'll just use it while the power bank is on.
However can someone tell me what the interface connector is called please (that connects the cradle to the clie) as I done a search and one of the results came up with "System-S" so I can get the correct USB cable for it.
Also the power is 5.2v - 1.3a so will it work on a power bank that is exactly 5v and nothing over it?
2 REPLIES 2
Anonymous
Not applicable
Hi there,
Hopefully a community member can help.
Best wishes,
M
willie5QB
MarkIpswich, well, I'm not quite sure about your power bank, but I charge my phone by using Quick Charge 3.0 from Villain ( this power bank: https://www.amazon.com/dp/B08527CGRT ), and it works way better than a previous charging standard. Maybe what you're looking for is - System-S USB A to Dual 30-pin dock connector sync & charge cable ? I've seen some of them on Amazon several times.
