where can i get the HotKey/Fn Key utility? for S3HP
Marcos
I've looked and can't find or work out which thing to download to get HotKey functionality back
is it tied in with something else?
2 REPLIES 2
rich912
Contributor
Hi Marcos,
Download the pre-installed utilities for your model from Vaio Link and extract the file. Then install the following in this order:
1 Sony Utilities (Installer Folder 1)
2 Sony Shared Library (Installer Folder 2)
3 Vaio Event Service (Installer Folder 6)
Then re-boot.
You may find that you need to repeat this process a couple times before the hotkeys work.
Go n-éirí an bóthar leat
Marcos
thanks, does this install other things too? the reason i got rid of a lot of things at the start is because of how bloated it all was. if hotkeys were just a single neat app i wouldnt mind it.
