When do i need upgrading memory module?
bardjoel
Hi al,
Recently, I ran a bit computational work using Matlab in my laptop VGB-B1XP. Then I received a message say, virtual low memory.
Does it meants I need to upgrade my memory module?
I've check the program & it turns out that the program need memory beyond the capability of 32bits machine.
Thanks in advance for any comments...
regards
Bart
2 REPLIES 2
profile.country.de_DE.title
seb21__
If your VAIO becomes horrible slow, then I would upgrade the RAM. Take a look at "CRUCIAL". But you could add more space for Virtual memory.
    disable Virtual Memory (swapfile or hiberfil)
    restart your VAIO
    creat a new swap file with a size of 2-2.5x of your RAM (1215MB for example)
    Take the same size for min. and max.
I had the same problem like you. That's why I use a bigger one.
But, if you need regulary so much RAM, then it's better for an upgrade.
kee-lo_
I'd say when you need more powerful software - then you should consider buying RAM
