Vaio not keeping time
chrislynch
Hi, My Vaio is not keeping time and will not syn. with the two default time servers any Idea what is causing the problem.
Chris
1 REPLY 1
Blencogo
Hi Chris,
I can only think that your firewall needs configuring to allow the time servers. What Firewall are you using?
Do you get an error message when you try to update manually? If something is turned off (like the Windows Time Service), you should get an error.
Reset time and date first because it will not update if the two times are very different (more than 15 hours). For this reason, check you have the correct Time Zone set - if you do not it may think your clock is more than 15 hours adrift. You should have GMT/Dublin/Edinburgh with the Daylight Saving box checked.
:thinking:
