Upgrading RAM further than 2gb
runaway64
Recently RAM modules of 2gb have dropped their price over here to a reasonable 100€;
I know from the specifications pages, that AR laptops, in theroy can only take up to 2gb of total ram.
Has anyone tried modules of 2gb? Maybe 2 modules of 2gb to get 4gb??
I would like to find out your personal experiences about this matter.
Thank your for your help and time.
5 REPLIES 5
Suberashii
I don't think that it will work.. I once tried it on my desktop that can handel 2gb of ram and it has 4 ram slots so i tried to put in 3gb of ram (in total) but at the startup it said that i am over the limit of ram.... So i don't think that is going to work... Anyway good luck with trying....
Thalamus.
Champion
Hi runaway64,
No the maximum RAM that you can put into your AR31 is 2GB... :slight_frown:
Dekesh
if vista is installed wouldnt you be able to use more than 2GB? Does certain vista versions not support much more than 2GB RAM?
rich912
Contributor
It’s not really a question of whether the operating system can use the additional RAM, more to the point is, can your hardware recognise and reliably use more that the maximum recommended RAM…
Go n-éirí an bóthar leat
profile.country.de_DE.title
seb21__
That's correct.
And most mainboards with support of more than 2GB Ram having some limitations.
Such as memory frequency and latency.
I have 4GB of Ram in my Desktop. The Ram works at 166MHz (DDR-333). The board does not boot with 200MHz (DDR-400). It did not change with todays DDR2 mainboards. (166MHz = DDR2-667(DDR3-1333), 200MHz = DDR2-800)
Then there is the latency. Most consumer boards supports a Command Rate of 1T. But only 2T with max. Ram configuration. (anyway 2T is best way to get a truly stable system)
At the end I'm losing ~1,9GB/s of memory bandwidth.
Well if you do photo/video editing, you can't have enough Ram. When Vista is running out of memory then it is using your harddisk as a memory replacement. And that is a much bigger perfomance loss than 2GB memory bandwidth less.
The harddisk in my Desktop PC has a avarage memory bandwidth of ~70-80MB/s "only"!
