Hi all,
Just a quick question.I am thinking of upgrading my hdd on my vaio ar-21s.It has 2 sata hdd(100gig each) and i would like to install a 250gig in each slot.Is this possible and would i be able to reinstall xp mce 2005 from the recovery discs etc.
Thanks :smileygrin:
why d'ont you make a copy of each disk...or are they in sata 0?
Your existing discs will be in RAID 0 configuration - so remember you will not be able to read from them externally. Use something like Acronis to save your data to an external drive. I would also make several copies of the Recovery Media and test that it works first.
The Recovery Discs will allow you to reinstall the original Operating System - and even allow you to choose RAID 0, RAID 1 or two seperate discs.
Hi again,
Thanks to you both for the advice. :smileygrin:
