TASK MANAGER
PERPETUAL
TASK MANAGER
Please could anyone advise ... my Task Manager no longer works when I press Ctrl-Alt-Delete??
My Platform is Windows Vista Home premium & it has worked in the past.
4 REPLIES 4
Blencogo
Try
Ctrl+Shift+Esc
as an alternative.
:thinking:
PERPETUAL
Thank you for suggestion however this did not resolve problem.
Perpetual
ChalkyWhite71
It could be that on a previous use of the Task Manager, you've inadvertently dragged it off the screen (or to within an inch of it's life!).
Try minimizing all and even drag the Taskbar down to occupy 0 lines of the bottom of your screen, then when pressing CTRL+SHIFT+ESC look for the top edge of the Task Manager window appearing on the far extremes of your screen.
Alternatively try increasing the resolution of your image, giving you more screen space for TM to appear within.
Hope this helps!?
drumkat
Right click on your taskbar and you should have an option to start from the menu that appears, hope this helps.
