My brand new FZ4 won't wake up from sleep (from either shutting the lid or if just not used for a while).
When I make it go to sleep from the start menu attempting to resume left me with a blank screen and I had to hold the power button down until it switched off and then restart.
When I shut the lid or it goes to sleep on its own the screen comes up in the wrong resolution.
Any suggestions? Help please
Sounds like a graphic card driver problem -Check here for any updates for your model
The only other thing is that it is a BIOS issue and if there is an update for that you will find it in the same location
Hope this helps
