Split hard drive's
euanscotland
Split hard drive's
HELP hopefully someone can???
my hard drive is split into c drive and d drive C is 37.2 gigs and d is 30.2 the problem is I have almost filled the c with itunes and not sure how to get the use of the d withought screwing up my i tunes
I guess the question is will it automaticaly go onto the other drive (d) or do I have to relocate files or ????
Euan
4 REPLIES 4
tatoe_nunk
Hello, you can either back up files and remove partition or just relocate files making sure you tell the programme that uses them where they are. If you need help removing a partition use windows troubleshooter as that has a stepby step guide to safely removing a partion. :smileygrin:
Thalamus.
Champion
Hi Euan,
Once you C drive is full the files DO NOT simply move onto the D drive, you have to physically move files from your C to the D drive..
You can move your My Documents folder to the D drive, here is a guide on How to Change the Default Location
I'm not sure, as I dont us Itunes, on the correct process to follow to move your Itunes tracks from the C drive to the D drive, whilst keeping all the file association, song ratings, etc intact,,
Maybe some other member can help with this.. :thinking:
euanscotland
Thank you sir,
I have opted for an external hard disk as im going to need pretty much 80 gigs to fill the ipod which is more than the Vaio has any way DOH! should have done the maths earlier
cheers
Euan
Thalamus.
Champion
You're welcome Euan.. :slight_smile:
