Hi, can anyone help me. my Sony Viao, has a blank screen.
You can just see the desktop, and sometimes on start up, it comes on for a split second.
Can anyone help.
If you can see the desktop, the likely cause is the backlight not working.
Does the desktop look normal when you shine a torch on it?
Try attaching an external monitor - is the display normal?
You probably need a new inverter - which supplies high voltage to the backlight. But it could be just a bad connection to the inverter. Inverters cost about £25 - have a look here: -
http://www.notebookworks.co.uk/new-sony-vaio-vgnfs-vgnbx-pcgfx-series-inverter-cseb6-p-11702.html
You will need someone to look inside to find the exact cause. If you want to try this yourself, send me your email by PM and I will send you a generic BX-Series manual.
Thank's for that. My screen has been on, but flickers then turns off.
You can see the desktop screen very vaguely. I am using a monitor at the moment.
Yes, I would like to fit it myself. I think that part is under the screen
Thank's lclarky.
Hi Iclarky,
I have sent the manual but I am not sure how difficult it is to get to the inverter.
It may be worth just looking inside for loose wiring first?????
Good Luck
Hello Blencogo/Iclarky.
I have recently experienced exactly the same symptoms!
I'm very interested to know if Blencogo's suggested fix worked?
I would be very keen to take on the repair work as I'm finding it impossible to source a laptop replacement with a screen which get's close to the resolution of the VGNBX297XP.
Hoping you can help!
